Those using Th400 and stock shifter come in!!
Old Oct 12, 2010 | 04:13 PM
Dean95z28's Avatar
Default Those using Th400 and stock shifter come in!!
I have been driving my car with this setup for a while but have always had some gate alignment issues. I think my problem is in the arm that is mounted to the shaft on the side of the tranny. I used the one from the stock 4l60e, but I think the throw or the clocking is off some. What gear selecter arm are you guys using to make this correct?
Old Oct 13, 2010 | 02:16 PM
Dean95z28's Avatar
bumpity bumpity
Old Oct 13, 2010 | 11:48 PM
dnkynrbk's Avatar
just spend the money and get a b&m ratchet shifter. Its not worth all the headaches.
Old Oct 14, 2010 | 01:39 PM
miller456's Avatar
i said screw getting the gates to line up as long as it went into gear and locked out reverse when upshifting being its not a rmvb.
