4l60e Grinding Noise when in neutral
I pulled over check my fluids still bright red and wasnt burnt. So i started to drive again i found out if i put it in neutral when im going over 40mph it will make this metal on metal grinding noise coming from the tail housing the faster i go the louder it is.
Truck still pulls great chirps the 1-2 shift and every gear works and shifts fine the transmission only has about 5000 miles on it since the rebuild. Any ideas??
Without throwing random guesses out there it would be best to check the trans pan and filter for metal and then rear. Where theres metal theres your problem.
