po502 code slipping 4l60e after stall install
Old Oct 31, 2010 | 06:04 PM
pat-ls101's Avatar
Default po502 code slipping 4l60e after stall install
I just installed a Yank 3600 about a 2 months ago and l did the 200 mile break in period. I haven't got on it at all since I installed it, so today I tried. I stopped, put my foot on the brake, and put my foot on the gas for a quick burnoout. Second later, no smoke so I shut it down. It was in D and just reving up. So I went to take off regularly and it took off sluggish acting like it was in 2nd. It wouldnt shift. I took it home and went through the gears 1st to OD.
It sounded like it was engaging but making a clunking noise each time. It even had reverse. Also, checked the fluid. It was topped off and clean
No burned smell. Scanned for codes; got a po502 vehicle speed sensor low input. Did I toast my trans? Any input would be greatly appreciated. Tried a search, couldn't find anything?
Old Oct 31, 2010 | 09:20 PM
performabuilt's Avatar
LS1Tech Sponsor
No VSS wil cause the no shift but sounds like you hit limp mode after you turned car off and restarted did ti go back to normal ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 31, 2010 | 11:28 PM
pat-ls101's Avatar
I just shut it off and scanned the codes. Haven't tried to restart it. What would have made it go into limp mode? I just tried to burnout?
Old Nov 1, 2010 | 05:41 PM
pat-ls101's Avatar
Went back and started the car, it runs and shifts great! no issues! What would cause it to go into limp mode?
Old Nov 1, 2010 | 09:03 PM
Jays_SSZ28's Avatar
A higher stall speed will cause this. The stock programming expects a certain amount of rpm drop down after it shifts, if it see's less of a change it 'thinks' it's slipping.
Some codes need to be set to not report a problem (since there is no problem)
P0751
P0757
It's a good idea to increase the lower numbers in the misfire tables since a smaller diameter converter will cause false misfire detection.
