Electri speedometer
Old Nov 3, 2010 | 07:29 PM
stewdie's Avatar
Default Electri speedometer
I have 1998 4L60E trans/ LS1 engine. I need to hook the electric speedometer up. It is the TPI speedometer. I was told to hook the two wires off of the back of the speedo ( Black-White ) to the trans. But have no ideas to which wires on the trans. I cut into the two wire plug at the rear of the trans and at that point the car would not shift out of 1st gear. This is in a 1952 Chevy wagon. Is there anyone that could help?
Old Nov 4, 2010 | 07:38 PM
Jays_SSZ28's Avatar
The vss signal needs to go to the pcm, then the speedo wires come out of the pcm to the speedo.
Right now it doesn't shift because the pcm doesn't know how fast the car is going.
