4L80E Swap?
Old Feb 2, 2004 | 08:23 PM
ss427ci's Avatar
Default 4L80E Swap?
Has anyone attempted a Heavy Duty 4L80E swap into an f-body? I believe it is the tranny in 2500 and 3500 HD pickups. I would think it would be a very stong tranny and could retain 4-speed capability, opposed to a TH400. Does anyone think this is even possible?
Old Feb 2, 2004 | 08:52 PM
whitt1's Avatar
The 4L80E is almost the same size as a TH400,you need a HD or 2500 flywheel,a converter,a crank spacer(from a 01 or later 6.0 in 2500),a modified crossmember(the pan extends past the 4L60E mount although the transmission is only a fraction of an inch longer),a 99 or later 4L80E(with LS1 bellhousing),a nuetral position switch with bracket,a TH400 driveshaft yoke and either a stand alone computer,custom PCM tuning with harness or a full manual valvebody.I think it's been done in an f-body before,my swap was done in a truck.
Old Feb 4, 2004 | 09:14 PM
ss427ci's Avatar
Thanks for the info.
I guess no one else has even thought of this besides me and you...........weird?
Old Feb 5, 2004 | 12:14 AM
BizZzatch350's Avatar
Moderator
No, its been done before. There was a TT C4 SBC Vette running one. I think it weighs a lot.
Old Feb 5, 2004 | 12:49 AM
DeepBlueZ's Avatar
its something like 30-40 lbs heavier than a 4L60/4L65 and it causes a lot more parasitic loss from the increased mass....also its a BITCH to fit in an f-body tranny tunnel tho it can be done right....on top of that you get TH400 gear ratios which are dead as hell compared to L60/L65 ratios...
4L60E 4L80E
3.06 2.48
1.62 1.48
1.00 1.00
0.69 0.75
its JMO but i dont think its really worthwhile in an f-body.
Old Feb 6, 2004 | 01:23 AM
silverTA's Avatar
there is a guy was thinking to do it
https://ls1tech.com/forums/showthrea...ight=4l80+swap
Old Feb 9, 2004 | 07:01 AM
JoBy's Avatar
A few non LS1 cars using a 4L80E:
John Meaney's 1989 1,300hp Twin Turbo Corvette
http://www.erie.net/~gfalbert/johnm.htm
Jerry Myers' 1987 Twin Turbo Corvette
http://www.twinturbovette.net/Home1.htm
Monty's 1982 1200HP/1000TQ Twin Turbo SBC 427 Corvette
http://www.montygwilliams.com/
