My Story with 4l60e
My 4l60e First went out on me few months ago. I had already anticipated that so i had the TCI pro built ready for it. I rebuilt my gearbox fully. Car drove great for like 2 weeks. Then my band and 3rd gear clutches were burnt. We thought this happened because of a few races and abuses i've done to the car. So we rebuilt it again, Using Born Warner Band, and Z-pack clutches. Another 2 weeks later, same problem happened. I changed the sun-shell, and the band and the clutches. And this time, i removed the TCI-shift Boss from my car. Thinking it might have been causing a trouble. I also changed the Gearbox Housing, Valve body, and everything that might cause an oil failure or any other kind of failure. In other words I replaced my whole gearbox, got a used one, and rebuilt it and put it on the car. This time I drove the car for about 4 hours. And same problem comes. The car runs 1st gear, and doesn't shifts unless i rev it higher than 3K and when it shifts, it immediately skips 2nd gear, and shifts to 3rd gear. I removed my gearbox today, and found the Band slightly burnt, and the 3rd gear disks not in the same condition they were. Here is a pic of my band.
The band is being installed in the right way, and so is everything else. This is not the first 4l60e this shop rebuilds. So blaming the mechanic is out of question.
anyone faced this problem before ? What could the reason be ? My LS1 is stock, and high torque cant be it.
Help me, and help my pocket.
[IMG][/IMG]
Bands might burn, but chunks don't flake off after four hours. They reused the old band. (enough to blame the rebuilder)
Usually water will cause clutch and band material to delaminate like that.
That band does not have four hours drive time on it.
New, old, whatever, if your clutches looked like that as well then all the frictions used in that build got wet or exposed to some kind of solvent at some point.
