TCI RMVB for 4L80
Reverse pattern came about on TH400s because it was required to use the modulator circuits for a transbrake and no other functional reason.
I looked at making a 4L80 RMVB and the issue I see has to do with supporting the OD sprag with the overrun clutches in 1-2-3rd gear.
My experience with 4L80s has also taught me that the closer you leave the circuits to stock, the more consistant and reliable it will be.
I suspect Rossler had the same experiences when he designed his transbrake.
