Trans. Temp?????
I'm running a TCI 3800 with the B&M 24K GVW and after some in town driving and idling I get to around 183 or so in 70-75 degree weather. I haven't checked the temp after a long highway cruise. I was around 200 prior to the cooler.
Tim
Tim
Keep in mind when asking about or comparing trans temps, that if you are getting your trans temp readings from A-tap they will be higher than those from a regular trans temp gauge tapped into your pan.
