95 v6 car..help
Old Feb 6, 2004 | 01:06 PM
UGOT8's Avatar
Default 95 v6 car..help
Mother drives a 95 firebird with the 3.4
i know this isn't a v6 forum but since its the same tranny basically i figured you guys could help out..
here recently i think the neutral safety switch is getting stuck..
even when you mash the brake to the floor... mash the button on the **** as hard as you can.. and JERK the shifter it still won't budge.
you just have to wrestle with it for a while and it'll finally go in gear.. after its out of park its fine...
what causes this and is there an easy fix?
thanks a lot
Old Feb 6, 2004 | 08:59 PM
Cheatin' Chad's Avatar
If you think it's the switch pull the console and check it out. Might just need some cleaning.
Spilled anything on the console?
