4l60e with 4.10
I like to have your input based on your experince using 4.10 gears with 4l60e at the track 1/4 mile or 1/8 mile. I'm collecting parts to put them together until build a new motor for a turbo set up.
Now i'm working on my 8.8 rear end, i plan to have it ready at the end of january . February the car going to go to the bodyshop to refresh the paint.
In march i going to install a set of pacesetter FL headers,LS6 intake,ASP pulley,probably ls6 ported heads,new oil pump,new cam still looking what to use,stall like 3600 to 4k and 150 shoot with set of prostar 15 x 3.5 and 15 x 8 with hoosier tires 27.5 x 8" . Hope to go low 11s to high 10s @ 12x miles
Now i need to make my mind of gears to use with that set up, because i'm working on my rear end now.Thanks for you input.
If this is your daily driver then stick with a 3500 stall and 3:73 gears.
Thanks for your info.
What camshaft you use with you set up when your car didn't make it to complete 1/4 mile? How well was your car in the 60 feet with the 4.10 and 3.73?
It is not may daily driver just some weekends and some fun at the track!
