Pulling tranny tommarow for converter install
Old Jan 14, 2011 | 12:13 AM
01ssreda4's Avatar
Front seal will be fine, let it be. Also, lube the nose of the converter where it plugs into the back of the crank. Make sure the pilot in the rear of the crank is clean and smooth. You dont want any binding here. Typically, when I do oil changes, I will remove the trans bellhousing inspection cover and spray some white lithium in an aresol up at the converter nub to keep some grease there. Do not pack it with grease, just a light coat of wheel bearing grease or something similar.
Old Jan 14, 2011 | 05:54 PM
z99ls1's Avatar
Restricted User
Got the tranny in today and everything bolted up and back together to spec. I measured with a feeler gauge and I got .245 to wedge between the stall and flex plate. So I put one of the .060 machined washers in wich got me to .185 gap and from the install instructions anything under .187 is fine so I left it at that. I drove it about 45 miles and than I had to do it. I revved it up to 2500 easily and launch it and the tires went up in smoke like never before lol. I havent tryed to stall it up all the way yet, but is it sposed to footbrake to 2500 like that? I think it will go further if I try. Anyways everything went good and holly **** this thing is fast now.
Old Jan 14, 2011 | 06:06 PM
jsteele90's Avatar
enjoy that stall.!!! start looking at daily driving drag radials to hook up!!
Old Jan 14, 2011 | 08:44 PM
01ssreda4's Avatar
Good work on the measuring. Nice to see people doing the job correctly.
Old Jan 14, 2011 | 08:48 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Glad to hear it all came together for you. I bet it feels like an entirely different car now.
Good job man! Keep us updated with track numbers.
Old Jan 14, 2011 | 09:02 PM
LaBLKv6Z's Avatar
Originally Posted by z99ls1
I only have 40k on it now so I think it should be good. What Circle D stall did you go with?
Ended up going with a 3600, it's replacing the TCI 3500 I burnt up.
Old Jan 15, 2011 | 12:22 AM
z99ls1's Avatar
Restricted User
Thanks guys. HOLLLY CRAP lol. This thing is crazy. Completely different car. I can stall it up to about 3000 rpm and the tires don't stand a chance lol. Im going to get some nitto 275 nitto dr's, but I still don't know if those will hook at all.
Old Jan 15, 2011 | 12:28 AM
z99ls1's Avatar
Restricted User
Btw I will have some vids up soon
Old Jan 15, 2011 | 01:03 AM
zed28camaro's Avatar
can someone explain the spacer thing to me a little more in depth? I put a circle d 3200 in about 1500 miles ago without any spacers. I'm just trying to understand where you space it out at. Could this maybe be the cause of the drivetrain slack I think I'm feeling? The car also has the TCI flexplate if that matters.
Sorry to hijack btw.
Old Jan 15, 2011 | 01:08 AM
01ssreda4's Avatar
Spacing wont cause drivetrain slack. Check the "torque converter installations" thread in the stickys at the top of this section. Its all explained there.
Old Jan 15, 2011 | 01:17 AM
will do, figure if the cars out for winter anyhow might as well drop the trans if im not doing anything and something is potentially wrong
Old Jan 15, 2011 | 01:58 AM
  #32
z99ls1's Avatar
Restricted User
you dont have to pull it out. Take ur starter off and get in there and take ur converter to flywheel bolts outand push the converter all the way back into the tranny, you will have to take the bottom cap off and push the converter back with a flathead screwdriver. Than use a feeler gauge or some drill bits to put between the flywheel and converter mounting pad. If it is more than 3/16 or .187 than you are saposed to shim it with a washer on each bolt. The washers have to be machined. Chris at circle d sent me 6 washers for free. you put the washer in between the flywheel and the converter and than stick your bolt through and tightin it down. If you don't have more than a 3/16 gap than don't worry about it.
Old Jan 15, 2011 | 02:16 AM
  #33
z99ls1's Avatar
Restricted User
Oh and I moniturd my tranny temps with a scanner while I was driving around town for awhile in stop and go traffic. It was about 60 degrees today and even with stalling it and a cuple burnouts and traffic it never got above 170 degrees. So my temps are looking good so far.
Old Jan 15, 2011 | 11:23 AM
  #34
Badazz 97 TA's Avatar
let the thing flash.(going off slightly above idle) Itll prolly launch harder without stalling it up.
Old Jan 15, 2011 | 01:07 PM
  #35
z99ls1's Avatar
Restricted User
I dont wanna launch any harder lol. It spins for days. It spins tell I let off. Last night I reved it up and launched it and it was spinning up to 60 tell I let off and let it hook.
Old Jan 15, 2011 | 01:09 PM
  #36
z99ls1's Avatar
Restricted User
And a question for people with a stall. I notice it barely movves when ur just sitting there. I thought it would move a little more, but its probably normal right?
Old Jan 15, 2011 | 01:47 PM
  #37
mike13's Avatar
that's normal, best way for me to describe it would be the sensation of pulling a trailer.
Old Jan 15, 2011 | 01:51 PM
  #38
z99ls1's Avatar
Restricted User
Thanks I figured it was. A stall makes you actually have to drive the car a little lol
Old Jan 20, 2011 | 01:26 AM
  #39
hotjohnnyls1's Avatar
i cut my exhaust at the end of the y kind of the middle of the i part
