4l80e 2wd vs 4wd
Old Jan 22, 2011 | 09:03 PM
badblazeSS's Avatar
Default 4l80e 2wd vs 4wd
what is the difference and how will either effect a swap in my car? thanks
Old Jan 23, 2011 | 01:56 AM
Vince B's Avatar
Moderator
The 2wd would be best unless you plan on taking the whole trans apart and install a 2wd output shaft. There is a freeze plug in a 4x4 that will need to be removed and then an orifice plug needs to be installed for lube on a 2wd extension housing. Vince
Old Jan 23, 2011 | 07:15 AM
forcd ind's Avatar
like Vince said, the output shaft, and the speed sensor, and the little cup at the back needs one with the hole-rear housings are avail on ebay
Old Jan 23, 2011 | 08:24 AM
badblazeSS's Avatar
thanks to all!
