Stall & specing a new converter question
Old Jan 28, 2011 | 08:50 AM
mike13's Avatar
Default Stall & specing a new converter question
In the last 2 years I've been upgrading my turbo car, started with T67, then heads & cam w/t67, then TC76, then TC76 W/383, now 383 W/ST80.
I don't really understand the magic of converters but it seems that if you have a converter spec'd for X amount of torque and your start making more then it's spec'd for by a pretty good margin then you run into more then just a higher stall speed? Is that correct.
I always thought the stall speed went up and that was it but in my own experience with changing my combination and making more power in steps that it affects the converter in other ways. I've had a 3 different high end converters and when they're spec'd for the combination at that time work great. Once you get outside that envelope the stall speed increases but also they don't hit as hard are seem as connected to the power of the car.
I guess what I'm asking is it's not as simple as saying a 3600 stall converter spec'd for 450rwhp is going to be 4000 stall @ 550rwhp? As a example.
Old Jan 28, 2011 | 01:16 PM
Circle-D's Avatar
Foot Break Stall, Flash Stall, Efficiency, Coupling RPM, Shift Drop are all affected by input torque and changes in the torque curve. Turbos are also the hardest converter style to build, very sensitive.
Chris
Old Jan 28, 2011 | 02:54 PM
mike13's Avatar
that's interesting about the turbo stall converter.
