4l80e seals ?
Old Feb 4, 2011 | 02:47 PM
Billy1987's Avatar
Default 4l80e seals ?
I am rebuilding a 4l80e and i have messed up a few of the seals. Does any one know where i can find these seals without buying a complete kit. Here are some pics of the seals
Attached Thumbnails 4l80e  seals ?-img_0049.jpg   4l80e  seals ?-img_0050.jpg   4l80e  seals ?-img_0051.jpg
Old Feb 4, 2011 | 03:03 PM
Vince B's Avatar
Moderator
You can get those from Whatever it takes transmission parts(WIT). They are what is call turbine shaft Teflon seals. The smaller ones are for the forward clutch drum and the larger ones are for the stator tube. The next time you go to install them use the drum and the pump to size them so you do not have this issue again. Make sure to let them sit in these components for a while and you should be good to go. HTH Vince
Old Feb 4, 2011 | 03:36 PM
Billy1987's Avatar
Anyone know of any other place? They are only five dollars but they wont 15 to ship them. They are in louisville and im not 2 hours away i think its alittle high.
Old Feb 4, 2011 | 06:51 PM
forcd ind's Avatar
the shipping is gonna be the killer from most places-i think TCI has the split ones, use some trans grease to hold them together-a little tricky
Old Feb 4, 2011 | 06:59 PM
Vince B's Avatar
Moderator
Door-ease works well for this to.
Old Feb 5, 2011 | 07:55 AM
Billy1987's Avatar
Ok i will try tci and see what i come up with. Thanks
Old Feb 5, 2011 | 11:18 AM
Vince B's Avatar
Moderator
Try a local trans shop to see if they have some they will sell you or if they will get them for you.
