Cooler Lines...
I'd like to run stainless steel brainded lines with AN fittings to run from my trans cooler to the radiator and trans etc. I need to know what size lines and AN fittings I need? Any input is helpful.
Thanks, Sam
Thanks, Sam
#6 lines are fine-many times on here a source for the fittings has been posted
they are straight gasketed fittings, not tapered, although some will tell you to thread 1/4 pipe fittings in it, its not the thing to do
ATI Perf has the fittings, amoung others-i think they are 1/4 18 straight
sometimes their on ebay, i picked up a set for a 4l80e with the rear return
