The most unusual trans issue
Old Feb 10, 2011 | 04:21 PM
Mikes02Z28's Avatar
Exclamation The most unusual trans issue
This is the strangest thing and it has been going on for a while now. Once I have been driving for a few miles I loose excelleration. The enginge still revs, the RPMS still go up and down but I have no excelleration. Until I tap my brakes and then I get excelleration bake for a few mile until it hapens again and the I nee to tap the brakes to get the excelleration back. Has anyone ever had this problem or heard of this ever happening before. I have the stock trans, trans cooler and 103,000 miles on it. It still shifts smooth, is not leaking fluid and gets serviced every 30,000. I am clueless....
Old Feb 11, 2011 | 07:35 AM
Jeremy@RPMTransmissions's Avatar
What happens if you creep into the throttle in 4th gear cruising at highway speed? Does the RPM start to creep up again without accelerating?
Old Feb 11, 2011 | 04:06 PM
Mikes02Z28's Avatar
After driving at highway speeds for a few miles all of a sudden i will loose exceleration and the rpm's will stay steady and I can hear the engine just reving up like I am not in gear. I tap the brake pedal for a quick second and then put my foot back on the gas pedal and have exceleration again for about 5- 10 minutes and then it happens again. I don't have a regular trans shop that I frequent. I want to get it fixed but i am nervous that s shop is gonna say that I need a new trans when all it may be is a $15.00 part.
Old Feb 11, 2011 | 04:21 PM
RedHotG8's Avatar
It sounds like there's a problem with the torque converter slipping.
