Do I need a tune after stall install??
Old Feb 10, 2011 | 05:55 PM
PheonixLS1's Avatar
Default Do I need a tune after stall install??
Like the title says if I put a 3500 stall in my 2000 Trans AM will I be able to drive immediatley after or will I have to tow it to the dyno shop for a tune??
Old Feb 10, 2011 | 06:03 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
you'll be able to drive it immediately,just don't do any WOT as top end operating parameters might have to be adjusted/changed.
Old Feb 11, 2011 | 02:49 AM
01ssreda4's Avatar
It will be fine. I drove mine for a month or better untuned. If you lay into the gas directly after a shift it may throw a trans code and put the trans in limp mode. It will think the shift didnt take place and restrict the transmission functions. You will lose 1st, 4th, and lock-up. You will take off in 2nd and have one shift to 3rd and thats it. Its a real pain in the ***. You have to pull over and shut the car off to get it to reset.
Old Feb 11, 2011 | 07:27 AM
skat's Avatar
Yep exactly what is said above. Most throw code p0757 shift solenoid "B" stuck open.
Old Feb 11, 2011 | 08:53 AM
01ssreda4's Avatar
I think mine would throw a 787 code. It would throw it into limp mode everytime. It would be right after a shift I would lay into the throttle and it would pop the code like clock-work. I learned quickly to stop doing that.
Old Feb 11, 2011 | 02:39 PM
blackhawk0251's Avatar
Get it tuned, that way you will be able to have line pressures increased and have altered shift points etc. Enjoy the stall!
