Why shouldn't I get on it in OD?
things such as detonation or misfires can cause your car to unlock the 'verter giving the appearance of slip, might want to keep an eye on that if someone disabled or detuned such.
might you datalog your car and see whats really going on.
The car is almost 100% stock.
Speaking of datalogging. What would be the least expensive way to do this? If I have a laptop, how cheaply can I get away with interfacing it with my car?
Now I can't unless I'm cruising on the highway over 65 mph or it slips like a ****. For example, if I'm going 40 and the trans shifts to 4th, I can't even hold that speed without the trans slipping. I have to downshift back to 3rd until I reach 55-60.
If you're not referring to my problem specifically, then I have no comment.
nah man- i was reffering to the post in general. sorry for the confusion.
. If you want to impress a girl or bounce with a manual car then you can but the shifter down a gear but otherwise leave it alone. BTW if you are making those long highway runs and are nervous about the tranny blowing up just get a tranny temp gauge and rely on that. A tranny temp gauge is priceless if you are scared about blowing up your tranny.
. If you want to impress a girl or bounce with a manual car then you can but the shifter down a gear but otherwise leave it alone. BTW if you are making those long highway runs and are nervous about the tranny blowing up just get a tranny temp gauge and rely on that. A tranny temp gauge is priceless if you are scared about blowing up your tranny.Try spacing out some of your sentences. It makes it easier for others to read your ideas and opinions.
As far as which setting to drive in... the primary concern (and the topic of the thread) is what selection to use when "getting on it", or when driving at full or near full throttle. It may still be smarter in the long run to pop the selector into D for Camaro or 3 for Firebird if you know you're about to punch the throttle. It will save some stress on the 3-4 clutches by not having to downshift in or out of 4th gear.
Manually shifting through all the gears has been universally rejected by every F-body fan, so it must be bad.
When driving around in general, OD is better...but that should be obvious.
On another note, gm intended the transmission to always be left in 4th(od), they wouldn't expect customers to shift between 3rd and 4th depending on conditions.
I always cruise in D (3rd) and shift into OD (4th) on the freeway. When I race I always click into 4th gear at 4500 RPM which is about 96 MPH (low revving truck). Every single full pass I ever made (street or strip) I have gone 3-4 at WOT. It is not the fastest shift, it feels sort of soft but was always consistent and solid and the tranny never missed a beat. Plus when I was going max-effort I always engaged TCC Lockup switch which forces TCC lockup as SOON as the tranny hits 2nd gear. Therefore it is locked the rest of the way and through the 2-3 and 3-4 shifts. I have probably 500-700 passes with TCC lockup engaged. My stock TCC never wore out, just stopped dropping as much RPM but a 7500-mile ATF flush always fixed that right back to normal. When I drive normally and the ECM engages WOT TCC Lock at 69MPH in 3rd gear, it always feels like a small "50hp boost" of power, the truck literally surges forward and the passenger can notice.
Here is a video of one of my passes: http://s95370645.onlinehome.us/syclo...pt51_run12.mpg you can easily hear the shifts by the engine tone, at the 1/8 mile point you can hear the shift into TCC-Locked-3rd really bring the engine RPM down, and then you can hear the shift into 4th well before the ET lights illuminate.
Now here's the real kicker; I raced my truck at Road America 4 mile high speed road course last year and the tranny survived! Here is a photo: http://popularhotrodding.com/events/...speed_11_z.jpg
I ran 7 sessions of 20 minutes a piece, that is nearly 200 miles of WOT racing, and you can only imagine how many 3-4 WOT upshifts I punished this tranny with, the tranny temp gauge was right at the max 260 (just a hair under), top speeds 125 MPH (remember my 3rd gear only lasts until 96 MPH, and I turned the boost way down for this event cause I thought I'd blow the bottom end not being able to constantly monitor Knock retard like I do drag racing.)
So my point is to offer some evidence to prove it is possible for the "4L60" to last under power doing 3-4 WOT shifts and TCC WOT Lockups. My truck probably makes 450-500HP and 600FT-LB torque.
For what it's worth, the truck ran 13s and 12s most of it's life; I just recently got it into the 11s and I lost engine braking (small metal fragments in the pan, feels like it's in Neutral when you let off the gas or coast-down) and about 6 months later I pulled the trans and currently am installing a built trans & high stall TC.
Hope you guys found this interesting,
Josh Straub
91 GMC Syclone
