Vacuum Modulator Line
Old Feb 14, 2004 | 11:14 PM
Ed Blown Vert's Avatar
Default Vacuum Modulator Line
I just got my FLP tranny installed. And my installer forgot to use the metal line to the vacuum modulator and he wants to use a standard vacuum line because the tranny is already installed.
How important is it for me to use the metal line? And is there a easy way to get it in there without dropping the tranny?
Old Feb 15, 2004 | 08:21 AM
jfm's Avatar
jfm
On my Stage 3 Speed Inc it came with a clear line with a metal braid inside.You need to keep the line from being sucked shut for it to work properly.
The way I understand it is that if your line is closed,you will be running full line pressure all the time which is not good for the tranny.
I would get it fixed ASAP,it should be easy to install clear line with braid set up as it is very flexable.
Old Feb 15, 2004 | 10:16 AM
WILWAXU's Avatar
I use the thick "tranny cooler line style" black tubing. Works great.
You need something that doesn't collaspe when hot and under vacuum.
