c6 ls2 options
Old Mar 1, 2011 | 09:06 PM
ishmael's Avatar
Default c6 ls2 options
I've got a c6 ls2 out of an 06. What are my options for an auto tranny and what do I need to do to get there? Right now I have the engine, an ecu and the pedal. I'd like to go with a 4l65. If I get one from a 6L 1500 silverado I'm told I also need the pedal and maf. I'm wondering if there is a way to get around that or if there are any other ODs that I can run with my pedal and maf - possible with an aftermarket TCU if need be. Thoughts?
Old Mar 3, 2011 | 08:18 PM
Bo185's Avatar
You'll need a GM TCM and your harness modified to work with it. Then you can run a 4l60/65/70/80. You can reuse your pedal and MAF.
Old Mar 3, 2011 | 08:36 PM
ishmael's Avatar
I forgot I had this thread out there. After I posted this I made some calls. Aknovaman is going to be reworking my harness and ecm to make it work out.
thanks
Old Mar 4, 2011 | 07:52 AM
Jeremy@RPMTransmissions's Avatar
Don't forget about Speartech. He does fantastic work.
