4l80e full throttle shifts to 4th
Old Mar 2, 2011 | 01:36 PM
forcd ind's Avatar
Default 4l80e full throttle shifts to 4th
im getting ready to build another 4l80e-if i make a couple passes with the car its going into, i may run out of RPM,s before the 1/4 (eventually going to change the cam) can 4th take a full pass shift, is their an upgrade i can make while the trans is apart to help it survive-as i remember it didnt have a lot of clutches, but been awhile
engine is a Procharged 496, but im not running a lot of boost, budget engine
build
Old Mar 2, 2011 | 02:07 PM
Jake's Performance's Avatar
Shouldn't be an issue, be sure you keep the shift firmness tame but crisp. The clutch capacity is adequate, it will outlive the hard parts.
