older rossler transbrake instructions
this was purchased in 2007
thanks
I should add that we have BS3 running the engine as well as the 4l80
Here is a verbal creation of what the pinout looks like looking at it from the side of the trans. The trans is in the car right now.
BS3 connector
top row 4 wires(uses all pins)
second row 1 wire(positioned to the far left pin)
third row 6 wires(uses all pins)
bottom row...White/purple stripe(far left pin)........wire going to transbrake button(far right pin) middle two pins not used
The pinout on the transmission connector matches the harness connector except there is no pin for the white/purple stripe(bottom row far left).
The wire I have going to the t-brake buttom matches the red wire (bottom row far right pin) that goes to the t-brake solenoid.
I dont know what the white/purple stripe is?
This is a RPM 4l80 We got it new in 2007, but the trans has been sitting unused since then. We put it in my friends trans am.
thank you,
Brent
