Pinouts for 93 4l60
Old Mar 10, 2011 | 08:24 AM
jdway93z28's Avatar
Default Pinouts for 93 4l60
Does anyone know a website that will tell me this. Like what is pin a,b,c,d,e for?
Old Mar 12, 2011 | 05:51 PM
jdway93z28's Avatar
Anyone
Old Mar 12, 2011 | 08:53 PM
Vince B's Avatar
Moderator
I have some info on a note that has pin ID's on it. I believe the info below to be correct and can be verified in an ATSG manual for the 700R4. I do not have a ATSG book here at the house but I can take a look this week while I'm at work.
(A) is BAT + for the lockup solenoid
(B) is 4th clutch
(C) is 3rd clutch
(D) is BAT - for the lock up solenoid
(E) is 2nd clutch
This harness also has a plug for a temp switch that is pig tailed in with the ground wire for the lock up solenoid and the 4rd clutch pressure switch. I'm positive on the power and ground terminals for the LU solenoid if this is what you are after. HTH Vince
Old Mar 13, 2011 | 05:47 PM
jdway93z28's Avatar
Ok. That sounds about right. Thanks
