flex plate
Old Mar 11, 2011 | 01:35 AM
tatum1's Avatar
Default flex plate
My 6.0 LQ4 was set up to run a 4l80e. I’m putting a 4l60e in the car how do I order a flex plate for the l460e with a 6.0. parts place said that don’t show a 4l60e hooked to any 6.0. Do you have a part number for the flex plate I need?
Old Mar 11, 2011 | 04:51 AM
tatum1's Avatar
oh my lq4 is a 1999-2002 and the trans is a 2002
Old Mar 11, 2011 | 07:27 AM
Mac 2002 SS's Avatar
give www.speedinc.com a shout . they may be able to help you.
Old Mar 11, 2011 | 10:13 AM
Bo185's Avatar
Just buy a 5.3L dished flex plate. You'll need the shorter crank bolts as well. Buy a used one it will be cheaper.
The 6.0L LQ9 were bolted to the 4l60/65 in the Esclades, SS trucks, VHO, and V-max's. The LQ4 also used the 4l60 in the C3 GMC's as well as the H2 hummers.
Old Mar 12, 2011 | 01:39 PM
JSmitty53's Avatar
I have a Trailblazer SS that has the 6.0 and the 4L60e trans...I just ordered a new TCI flexplate from race-mart.com it was the cheapest I found.. part number is tci-399753. Everybody that I talked to said its a very good upgrade from stock... I hope this helps
