vibrating under center console
Old Mar 13, 2011 | 09:09 PM
need4fun2469's Avatar
Default vibrating under center console
I have developed a vibration under the center console. It sounds like a rotational vibration because it slows down when the car does. I can hear pauses when I almost come to a complete stop.
I replaced the drive shaft a week ago thinking that it was at fault.
Any insight or suggestions?
I have checked all the mounts underneath the car, no signs of anything rubbing or along those lines.
Old Mar 14, 2011 | 12:04 AM
Zac2003's Avatar
did you replace ujoints I am going through somethimg similar right now put it on jack stands with wheels off tonight and got it up to speed and the rotor looks warped pretty bad hopefully that is my issue... let us know what ya find out
Old Mar 14, 2011 | 04:25 AM
new ds came with new u-joints
Old Mar 15, 2011 | 12:31 PM
Zac2003's Avatar
do you have a rubber tranny mount or polyurathane ??? mine is poly I am thinking that might be the issue...
Old Mar 15, 2011 | 01:01 PM
I have a rubber mount. Looked at it a couple days ago and it is good shape. I wouldn't put a poly in because what everyone has said about the noise
Old Mar 15, 2011 | 01:11 PM
Jays_SSZ28's Avatar
Did you check the tail housing bushing?
What are you using for a torque arm and torque arm bushing?
Old Mar 15, 2011 | 10:57 PM
checked taihousing, nothing looks wrong.
factory tq arm and bushing. Bushing looks ok.
