2007 4l60?
Old Mar 14, 2011 | 03:47 PM
jsanford's Avatar
Default 2007 4l60?
Will a 2007 4l60 run independant from the engine if it has the harness and transmission control module? I have a 09 5.3 that I'm going to put a carb on and I need a trans. I'm currently looking at a 700r4, but I've found a good deal on a 2007 4l60 that was behind a 5.3. I'm just confused on what 4l60 will work.
Old Mar 14, 2011 | 07:37 PM
Bo185's Avatar
No you need an aftermarket standalone system or manual valve body. It wont work with just the TCM it needs inputs from the motors ECM. Just get a 700r4 with the right flexplate. And connect the TV cable to the carb. Be cheapest route,
