is this what i need?
Old Mar 15, 2011 | 05:39 PM
Trevor F's Avatar
Default is this what i need?
Is this what i need to mount my ls motor to a 700r4 trans?
http://www.advanceadapters.com/products/pn-712500a/
Is this the best deal or is there something better for less?
Old Mar 16, 2011 | 06:35 PM
Jays_SSZ28's Avatar
That would work.
There are several adapters and flexplates out there, that kit has the weaker stock flexplate.
Old Mar 16, 2011 | 08:59 PM
Trevor F's Avatar
ok well i have a flexplate. Just no clue what its from. I know it was on a 5.3 not sure 2wd or 4wd.
Its part number 12580709 so if i can use it and just buy a spacer that would be way better imo.
anyone have an idea if i can use it?
Old Mar 16, 2011 | 11:13 PM
Jays_SSZ28's Avatar
Early 5.3's came with a spacer and a flexplate that would work. GM was basically adapting the older style transmissions to them in some applications.
Old Mar 16, 2011 | 11:41 PM
Trevor F's Avatar
any idea on the part number for the spacer?
Also this should have been off a newer 5.3 like 03+ it has the DBW throttle body.
