Need help!!!!!!!!!!!!!!!
Old Apr 22, 2011 | 02:59 AM
victor111262's Avatar
Exclamation Need help!!!!!!!!!!!!!!!
i was driving a 2k z28 auto and hit a bump at about 45 with the bottom of the car, then it just start acting like it went to neutral, i stop and check it didnt go to neutral, but every gear would go in but know it had a weird winning noise coming from the front like from between the engine and tranny, its not loud its just a little noise also the rpms go up by just putting it in gear to like 1500 when they use to drop when in gear,
So does anyone have an idea on what could be wrong, cos this is one of the weirdest thing that ever happened to me every gear goes in but if i press the gas the car don't go any where
Old Apr 22, 2011 | 07:52 AM
Predator T/A's Avatar
i would check the shifter adjustment or for damage to the shifter linkage on the side of the trans it probably got hit
Old Apr 22, 2011 | 09:36 AM
even if it goes into gear. thanks i give it a check
Old Apr 23, 2011 | 08:55 PM
98pontiacfirehawk's Avatar
This must of been one large bump! Did it hit the trans pan? If so check and see it didn't break the filter tube off into the tranny. From what you are saying it’s whining at the front pump like it starving for fluid. Also, check you tranny lines for any abnormal bends cutting off fluid. While you are under the car go ahead a check to make sure you are getting a good connection from you wiring harness to you tranny that big hub on the passenger side.
Old Apr 24, 2011 | 12:46 AM
hell yea it was and yea ill check, that out i hope it has to do with the pump
