what stall?
Old Apr 24, 2011 | 10:36 AM
camarorat's Avatar
Default what stall?
Im running ls motor dynoed at 450 HP 450 TQ, 390 gears A4 Auto, 28" rear tires. What stall should I be running
Old Apr 24, 2011 | 10:51 AM
01BlackCamaroSS's Avatar
what cam are you running
Old Apr 24, 2011 | 10:52 AM
Circle-D's Avatar
Need a little more info. Can you fill out an "Ask Chris" form, a link is in my sig. But need cam specs and intended usage.
Chris
Old Apr 24, 2011 | 10:55 AM
i would go with something in the area of a 3600 stall check out circle d they make some really nice stuff. I started out with a vig 3200 but a year later ended up pulling it out and sending it in for a restall to a 3600. I now a running the circle d 4c converter.
Old Apr 24, 2011 | 11:07 AM
kinglt-1's Avatar
3800-4000 range.
