4L60E Slips in 3rd gear
Its 2007 Envoy with 4.2L & 4l60e trany.
it started slipping in 3rd gear.No trouble codes
i tore it down found the 3-4 cluches fried,all the rest of the trans. looked good,so i cleaned it very well and installed new 3-4 cluches and most of the seals and gasket that came with kit following the manual.
2 things i noticed
1- 3/4 cluches were kind of dry,like not enough fluid getting there
2- the clearence in 3/4 cluch suppose to be 1.90 mm-2.10 mm according to the manual, but it was like 3 mm.
put it back together it drove good for 2 days then again same problem,slipping in the 3rd gear, now i have it apart again and seems the 3l4 cluches burning again.
what should i look for to solve this problem?
thanks for any help in advance.
Edit on a stock unit I would shoot for .040-.060. Rule of thumb is .008-.010 per friction.
