4x4 4l60e - LS1 Fbody
Old May 6, 2011 | 03:04 PM
IamSam's Avatar
Default 4x4 4l60e - LS1 Fbody
My trans in my camaro needs to be replaced, I dont have the money to rebuild it so replacing is my best bet. All salvage yards want at least $800.. so I found this 4wd 4l60 out of a 5.3 Silverado, has 10k miles on rebuild. What would I have to do to make this work? I just want a straight forward answer because I need to act quick.
I understand that I need to dissamble it partially to change output shafts, will I need any special toos besides the snap ring pliers? Thanks!
Old May 6, 2011 | 05:16 PM
Vince B's Avatar
Moderator
You will need a torx 50 plus to get the bell housing off. The linkage shaft and the 2nd gear servo should be swapped as well. If you have a trans shop near by you might want to have them do this stuff for you. I would think that a shop should be able to do this in an hour. Vince
