Im completely stumped :(
Old May 23, 2011 | 02:24 AM
HDtech's Avatar
When is the last time the pan has been off the trans? Have you checked the fluid? Does it smell burnt or anything? It could be that someone left out a checkball or spring when/if the valve body was out.
Old May 23, 2011 | 06:49 AM
Vince B's Avatar
Moderator
Do you have a MIL light on for a transmission code? In some cases a transmission code will put your trans into a high line pressure condition. When this happens the shifts become much more noticeable and this might be your issue. If not I would assume that either your trans has a shift kit installed or the pressures in your computer might have been altered. HTH Vince B
Old May 23, 2011 | 11:54 PM
Nando92's Avatar
only 14,5xx miles on trans, no MIL lights, no burning smell...
maybe the owner before me put on a shift kit or something..
Old May 24, 2011 | 07:05 AM
SS SLP2's Avatar
I also think " high line pressure " have your tuner check it, as he /she may have upped it while tuning, or go to a good trans shop and have it scanned
Johnny
Old May 24, 2011 | 05:03 PM
Elthesh's Avatar
On my 99Z, the tranny was built and setup for hard shifts all the time, so just cruising from a light, on the 1-2 shift, the shifts were so hard that they literally knocked your foot off the accelerator.
