glide sat for a while, wont go into gear
Old May 20, 2011 | 01:44 PM
ElkySS's Avatar
Default glide sat for a while, wont go into gear
i got a powerglide. when it was pulled, it was running great, only has about 30 miles on it. it then sat for 3 years. we put it back in a car and now it wont go into any gear. anyone know why?
Old May 20, 2011 | 11:00 PM
ElkySS's Avatar
got a th350 that did the same thing. figured this problem might be pretty common
Old May 22, 2011 | 10:12 AM
ElkySS's Avatar
this has never happened to any one? really?
Old May 23, 2011 | 10:28 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
First thing you need to check is to see if it pumping fluid and has line pressure. The top line is the return line. Remove it from the trans and put it in a 1 gallon bottle. It should pump a quart in 30 secs. If it is not pumping the problem is the pump.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old May 24, 2011 | 09:56 AM
ElkySS's Avatar
ok ill give it a try. thanks!
