Using 4l80-e from 2000 Suburban, 4wd?
Old May 21, 2011 | 03:36 PM
Superman09's Avatar
LS1Tech Sponsor
Default Using 4l80-e from 2000 Suburban, 4wd?
I have access to a 4l80-e from a 2000 4wd Suburban. Can I run this in a 98-02 f-body being it is a 4wd? I understand all the conversion parts for the swap of an 80-e into an f-body, but what all needs to be done to this trans specifically to work if possible? Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old May 21, 2011 | 04:08 PM
cabel1's Avatar
Output shaft and tailhousing need to be changed
Old May 21, 2011 | 08:37 PM
Vortech Converters's Avatar
Restricted User
Default I Know You Have
My number on speed dial. Output and tail housing have to change.
Old May 22, 2011 | 08:18 AM
Vince B's Avatar
Moderator
Don't forget the orfice plug in the back of the case.
Old May 23, 2011 | 10:22 AM
slow67's Avatar
Gingervitis Addict
And make sure there is a Reluctor wheel for the VSS pressed on.
