shifting problems
Old May 23, 2011 | 08:34 PM
kosimoto's Avatar
Default shifting problems
I Took the car out this last weekend to the dragstrip. Im having shifting issues, the 1-2 shift is about 6300 but the pcm says 6000 and 2-3 shift is 6500 and hitting the rev limiter and then shifting and the computer says 5900 rpm at WOT. your help would be appreciated thanks
Old May 23, 2011 | 11:48 PM
projectX's Avatar
It sounds like either the shift points were adjusted not according to the rev limiter also, If your 2-3 is bouncing off rev limiter - could be your clutches going.
Old May 24, 2011 | 07:58 PM
kosimoto's Avatar
tranny was just rebuilt. Ithink I will try lowering all shift points by 500 rpm to see if that makes a difference. thanks for input
Old May 24, 2011 | 11:56 PM
projectX's Avatar
Try adjusting your shift point lower than your rev limiter.
Old May 25, 2011 | 06:48 AM
kosimoto's Avatar
I will try that
Old Jun 5, 2011 | 12:42 AM
kosimoto's Avatar
I figured it out, thanks
Old Jun 5, 2011 | 12:57 AM
Vince B's Avatar
Moderator
Post was fixed your issue so it will help others in the future!
