Re-mounted my trans cooler
Old Jun 7, 2011 | 11:50 PM
c5z28's Avatar
Default Re-mounted my trans cooler
Used to have it dope style and have decided to cut some of that foam away that was up in the front.
I have cleaned the front since the pics
Old Jun 8, 2011 | 12:40 AM
01ssreda4's Avatar
Showing any difference in temp? Or do you not have a tranny temp gauge?
Old Jun 8, 2011 | 11:02 AM
senicalj4579's Avatar
I bet it will run hotter like that. Seems like theres less space for it to breath there vs dope no?
Old Jun 9, 2011 | 03:01 AM
c5z28's Avatar
No I don't have one. Althought I have done some runs in the past with a tt G-35 and as the runs progressed my pull became less and less. By the 5th run we were side by side. With the new mount the effect has been diminished.
Air is moving over the fins correctly in this position, and there is a hole behind the cooler as well. The opening is nearly as big as the cooler itself and it leaves more cool air for everything else.
