200-4r question
Old Jun 16, 2011 | 12:42 AM
TurbopigB4C's Avatar
Default 200-4r question
My Grand National block is no good and I have decided to go with a t76 5.3 project and already have a built 200-4r with transbrake in the car with a decent converter and wanted to know if I could make my current trans and converter setup work with the 5.3 engine. Do I need a different flexplate? or would it just be better to get a different converter?
Old Jun 16, 2011 | 02:06 AM
PBA's Avatar
PBA
When bolting an LS1 motor to non LS1 transmission, you will need a different flexplate.
Old Jun 16, 2011 | 06:16 PM
cabel1's Avatar
You should only need a crank spacer.
Old Jun 17, 2011 | 06:44 PM
bluethunder364's Avatar
I have a 200-4R behind a 6.0 (same) with a Hughes SFI flexplate with there LS1 spacer. Works fine. The spacer holds the front of the converter in line with the crank, plus provides added support. Spacer is about $40.00 Hope this helps!
Old Jun 17, 2011 | 07:05 PM
Thats what I needed to know this swap is becoming less intimidating by the minute. I really will only be limited speed wise because of funding.
