arp flexplate bolt tq specs.
Old Jun 18, 2011 | 12:31 PM
92slowmaro's Avatar
Default arp flexplate bolt tq specs.
i have searched around for the past 45mins on here and other sites and can not find the torque specs for the arp flexplate bolts they are the 12pt ones also. if anyone has the specs and could share that would be awesome. id like to get this 4l80e swap done...
Old Jun 18, 2011 | 08:55 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
60 ft lbs with ARP Moly Assembly Lube or 75 ft lbs with 30wt motor oil
