4L80e Direct clutch pack
I am going to tear my last 4L80e apart and just replace the directs, should I replace them with stock frictions or something else?
I don't know if its the stock frictions that can not hold the power or the lack of the directs being dual feed in whatever I have pulled the used trans out of. They seem to last a few thousand then start to slip on apply. Once they are applied they seem to be ok.
seems the cores i have bought the directs were pretty well used up, so a fresh rebuild would be fine, bushings, seals def help
