4l60e issue. no oil flowing.
just got it running today and the tranny is not working. wheels barely move when off the ground. i figured out there is no oil flowing thru the cooler up front. i was able to spin the converter freely by hand before i bolted it to the flexplate. i pulled the pan and everything is clean and in place in there. there was plenty of fluid.
i am not a tranny guy. seems like it must be the pump. is there anything i should check? if the pump did go bad or break is it likely that is ruined or polluted the rest of the tranny?
is it probable that i can just put a pump in it and be on my way or is there more to it than that.
You should be able to just repair the pump. It shouldnt have trashed the whole trans. But if the rotor is broken it could have stray pieces here and there.
Improper converter installation is the number one cause of zero pressure during an engine/converter/tranny swap...
i do not know the history of this tranny. i know it has been sitting for over a year before i got it.
so, plan is unbolt the converter. slide the converter back. check to see for sure that is spins freely and see how far it will slide back.
if i decide to put a pump in it would something like this be ok >> http://cgi.ebay.com/ebaymotors/4L60E...3#ht_632wt_939
if not can i get a suggestion on what pump to buy.
