Does this sound like a high price?
My 4x4 th350 went out. I found a great deal on a th350 2wd unit i couldnt pass up. Now from my knowledge i can just swap the output shafts. Tranny has to come apart but its just swapping the part.
Now rebuild kits are 150 from b&m. so that leaves 400 in labor? thing is im not even asking for a rebuild the tranny got is rebuilt with shift kits and everything in it. they want to charge 550 cause they might rip a bunch of gaskets? does that sound stupid? i thought u could get a th350 rebuilt from scratch for like 300 with no hard parts.
After reading my response I noticed that I didn't answer your question fully . Yes I think $550.00 is high , I would price that at around $200.00 plus gaskets if I had to tear down both units . You will need at least a pump gasket and o-ring if the two wheel drive unit is a fresh rebuild !!
Frank
