4l80e on the cheapo
Old Nov 16, 2013 | 09:41 PM
  #181
PUROCHEVY's Avatar
Default shift kit question
Originally Posted by Cam72aro
Shift gate and hd2 shift kit came in today. Converter is the only piece of the puzzle missing.
I have installed a few of the sk kits from transgo with mediocre results. I was expecting the tires to chirp on the upshifts, but no dice. I called transgo tech line and the man behind the curtain said those kits are [U]not[U] designed to do that simply correct the pressure rise problems.
He said the hd-2 kit would provide these results.
Does this sound accurate????
Thanks
Old Oct 10, 2014 | 10:13 AM
  #182
Avarookie's Avatar
I must have missed it if it is posted, what year of 80(e) will work for a 2003 5.3? I am using a 0411 comp, with the red and blue connectors, will this run the trans, or do I need a aftermarket one, such as the GHM? How do I know what year the trans is when looking at it in a bone yard? IIRC, the one I had in my Impala SS, you could tell by the casting on the right rear of the trans. There are two port plugs and three verticle lines in the casting directly underneath the port plugs.
Old Sep 12, 2017 | 10:52 PM
  #183
dhill70's Avatar
Default 4l80e swap
I'm trying to put a 4l80e in my 1976 k20 behind a 350 supercharged. I'm trying to figure out everything I need for this install.
Old Sep 13, 2017 | 06:50 AM
  #184
wht/73's Avatar
A 4WD 80E which I'm sure you have, Trans controller and cross member mods
and re configuring of cooler lines and a carb mounted tps for the controller.
I have a compushift controller with their tps switch.
Way better looking then the TCI one.
https://static1.squarespace.com/stat...PG?format=750w
