What to do??
Old Aug 9, 2011 | 09:26 AM
Leylah's Avatar
Default What to do??
So I get a code 24 which says Speed sensor too low...usually indicating the VSS right or wires? BUT the speedometer works still... would it still be the problem? This is for a Trans Am w/ 4L60E btw
This came up right after my car didnt want to go into gear. Went into first fine then RPMs shot up & didnt want to go into 2nd...Im so stuck, HELP!
Old Aug 9, 2011 | 11:33 AM
performabuilt's Avatar
LS1Tech Sponsor
Well if the engine reved but the car did not move or move as expected it could set that code.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 9, 2011 | 01:13 PM
Leylah's Avatar
well yea obviously... i know... question is...why? whats making it not shift
Old Aug 9, 2011 | 02:20 PM
Gilbert@Ace Racing's Avatar
A vehicle speed sensor can and will cause erratic or no upshift conditions. I would recommend replacing the sensor and go from there.
g
Old Aug 12, 2011 | 07:07 PM
Leylah's Avatar
Ok well...ended up NOT bein the problem!!!! uugh! so now what? VSS code gone but still spikes rpms & wont move
Old Aug 13, 2011 | 07:29 AM
I see, maybe I misunderstood your initial comment. A VSS will not cause an automatic transmission to not pull.
You probably need to have your transmission rebuilt. What is the fluid condition? Have you checked the fluid level?
Give me a call today. I'll help you sort it out.
g
