Trans not going into 3rd or 4th
Old Aug 15, 2011 | 01:07 PM
torqhead's Avatar
Default Trans not going into 3rd or 4th
Have a 2001 T/A with the v-8 and auto transmission. I believe it's the 4L60E. Anyhow, I can drive the car using manual shift and accel/decel in 1st and 2nd gear. When I move the shifter to 3rd the tranny changes, but the engine just rev's up, no pull. Any thoughts on what might be wrong, checked the fluid already. Is this something that can be resolved without removing the trans?
Old Aug 15, 2011 | 02:27 PM
72blownvert's Avatar
3-4 clutches are wiped out.Time for a rebuild.
Old Aug 16, 2011 | 07:53 AM
Gilbert@Ace Racing's Avatar
Unfortunately your transmission has lost the 3/4 clutches. There is not much you can do now except manage the repairs wisely. Be sure to have a reputable builder go through it so that you do not have this issue again anytime soon.
If you need some advice or would like to discuss options feel free to give me a call.
g
Old Aug 16, 2011 | 10:02 PM
performabuilt's Avatar
LS1Tech Sponsor
I would agree its time for a rebuild or a trans . No simple fix
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 16, 2011 | 10:44 PM
01ssreda4's Avatar
As stated, 3/4 is toast.
