COMMENTS ON THE B&M trans pack
Old Mar 5, 2004 | 07:46 PM
Jpr5690's Avatar
Default COMMENTS ON THE B&M trans pack
when i do my tci ssf3800, flexplate, deep pan, and bigger tranny cooler i was thinking of installing a b&m trans pack (the step up from the kit) it says you get gear selection when not in overdrive which seems benfical for hwy rolls ANAWAYS WHO HAS USED THIS KIT AND HOWS IT WORK\ COMPARE..... HOW WAS THE INSTALL COMPARED TO A REGULAR KIT ****ALSO****** I WAS GONNA UPGRADE MY 1800 GVW COOLER TO ONE OF THE FAN POWERED ONES IS THIS A GOOD IDEA OR EVEN NESSARY OR SHOULD I JUST STICK WITH THE 1800 GVW COOLER
THAKNS,
JOHN
Old Mar 6, 2004 | 05:54 AM
boomcase's Avatar
Ill let you know this week ,Im installing a new TCI 3800 stall and a B&M trans pak myself,
Old Mar 6, 2004 | 06:29 AM
Jpr5690's Avatar
gl...
Old Mar 7, 2004 | 12:47 AM
Jpr5690's Avatar
no one else?
Old Mar 10, 2004 | 05:36 PM
boomcase's Avatar
Well I installed the trans pack after I installed the my new 3800 stall , All and all it wasnt bad took me about 4hours ,(first Timer) Now I was hoping I did everything right so started it up added fluid and took it for a 2 mile drive, Well I will say this, I did the street strip app and with my new converter it really doesnt bang hard and it does shift pretty fast and firm (less sloppy feeling), all and all Im happy not bad for 75.00 . I hope everything holds up and works ok for a while But dam I gotta say that the converter is awesome, shreds the tires at 35mph
I give it a good review and would recommend it.
Old Mar 10, 2004 | 05:45 PM
Jpr5690's Avatar
thaks bc ... anyone else
