Removing Pan Gasket
Old Sep 9, 2011 | 12:15 AM
DropTopBird's Avatar
Default Removing Pan Gasket
Swapping the fluid and filter in my trans and Im having trouble getting the gasket off. Its hard as a rock and almost seems like its glued to the pan. As far as I know its the original gasket. A scraper isnt budging it and its just falling apart in the places that its not stuck fast. Anyone got any tips to help get this thing off?
Old Sep 9, 2011 | 01:53 AM
01ssreda4's Avatar
Tap the scraper handle with something. That will help it dig in. Sometimes it comes off in layers. You could try some gasket remover spray, though I have never used it before. I typically finish it off with a fine 2 inch scotch roloc disc on an angle grinder.
Old Sep 9, 2011 | 02:50 AM
Doing a little more research since the post, I did find that a common practice is to use 3M scotchbrite/roloc pads. Ill give the combination of those two a shot.
In a separate issue that I didnt think of until a few min ago, when I replaced the filter I forgot to lube the tube with fluid before I installed it. There was still some on the seal when I put it back in (which form this site I have read it was not good to change unless it was damaged). Should it be ok or should I pull it back out and lube everything up?
Old Sep 9, 2011 | 01:02 PM
pancho toco loco's Avatar
You should be ok w/ out the lube. Like you said the seal still had fluild on it.
Old Sep 14, 2011 | 11:34 PM
For the record, a sharp wood chisel and a roloc disk are the perfect combo for removing gaskets!
