T56 to Th350 Swap
Old Sep 17, 2011 | 01:22 PM
AChotrod's Avatar
Default T56 to Th350 Swap
Just making sure I dont need anything else when I start the swap.
Parts I have.
Built TH350
Flex plate
Shifter
trans cooler & lines
dip stick
t56 cross member
Im still deciding on the converter (prob getting a PTC or BTE)
Which bell housing, flex plate and TC bolts do I need?
Anything else you can think of???
Old Sep 17, 2011 | 05:24 PM
3rdgen92maro's Avatar
For the bell housing you can run the stock th350 housing or switch to a JW Bellhousing, for the flex plate I used a factory one from a a4 car when I did the swap in my formula.
Old Sep 18, 2011 | 12:29 PM
AChotrod's Avatar
My 350 has a JW bell and I have a flex plate.
Old Sep 18, 2011 | 06:34 PM
The JW bell will work then!
Old Sep 18, 2011 | 09:05 PM
4CamT/A's Avatar
im doing the same thing m6 to th350. I dont know what gears to put out back since im going to finish my turbo build.
Old Sep 20, 2011 | 06:21 PM
AChotrod's Avatar
I just need the bolts to attach the trans & flex plate. Not the actual bell and plate.
I have 4.10s now. Car should put down around 750rwhp. Prob gonna have to change them.
Also just ordered the TC
