4L60E issue
well i'm a newbie regarding transmissions, but i'd like your advice, my 4L60E has a problem with shifting gears, i don't know maybe it is just its way of working, running it by manual, you just make the shift at full throttle, it is not done until you lift throttle or it is at 6500 rpm, shift it's been done at 5000 rpm or sooner and you get same results. any input?
i needed some advice on this transmission from B n M performance if i would get my moneys worth out of it or should i just stick with the Gm factory trans?? that's the link to the BnM transmission.. im kinda new to this stuff so yeah.....
http://www.bmracing.com/PRODUCTS/GM/...ne-converter_3
Thats good info, thanks for getting back to me. It's not abnormal to see a "delayed" upshift in a stock transmission. When I build a performance unit, the primary thing I am looking for is a quick and firm upshift that is not violent.
Feel free to call me if you'd like more information or would like to discuss where you're expectations oughta be short term and long term based on your goals and budget.
g
g
