4l60e transmission shifting problem
Old Sep 19, 2011 | 04:35 PM
htex88's Avatar
Default 4l60e transmission shifting problem
I just rebuilt my transmission a week ago because the sunshell snapped, and also wouldnt shift into 3 or 4. Now that i have back in my truck, reverse is fine, but doesnt feel like its shifting from 1-2-3 and revs high. I can hear it down shift to first when shifting manually. and will move in manual 2 and 3 but revs high. any ideas as to what the deal is?
Old Sep 19, 2011 | 10:39 PM
performabuilt's Avatar
LS1Tech Sponsor
Sounds like your inlimp mode you sure the conector is seated right and you didnt pinch any wires?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 20, 2011 | 08:29 AM
JUNK's Avatar
As mentioned, default mode is 3rd gear w/ no power....check the fuses as well as the trans connector and wires......
Old Sep 25, 2011 | 03:47 AM
htex88's Avatar
I reconnected the trans connecter and all gears now work, but 4th gear is still slipping i think. im at 2500 rpms when doin 60, is this something will overtime fix itself since the transmission was just rebuilt? and also 1 doesnt shift into 2 until rpms are around 3000, sometimes i have to let off gas to shift.
