transgo help
Old Mar 7, 2004 | 04:48 PM
itchygomey98's Avatar
Default transgo help
When I took out my second accumulator housing, the piston is upside down compared to the diagram. Should I turn it the way the diagram shows?
Old Mar 7, 2004 | 07:15 PM
Wesley SS's Avatar
If i remember right no keep it the way it was not everything on the diagram is correct. I may be wrong hopefully some other people will say if im right or wrong.
Old Mar 8, 2004 | 10:28 AM
Smitty's Avatar
Install it as the instructions show that came with your Trans Go kit.
Old Mar 8, 2004 | 02:15 PM
Wesley SS's Avatar
IMKMFAST is right it I looked it up and it does have to be turned the way it shows.
Old Mar 8, 2004 | 02:26 PM
Sunset01's Avatar
Absolutely, transgo has you turn it over. Instructions clear as mud ! When you call their tech support, they are good though.
Old Mar 8, 2004 | 11:35 PM
Well the Tech support agrees, so that's how I put it together. I also had a question about which spring to use since I have billet servos, and they said white so that's what I did. I'm just wonderin if I should go ahead and drop it off at a tranny shop to have it dynoed or if I should just throw it in. The reason I wonder is cuz I won't be able to start this thing for a little while and I'd like to know it's good. Anyway, thanks for the help guys!
